Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Steering column question
Old 07-29-2003, 07:56 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
There is no way in the world I would do a billet item in a car of mine. Just go to Pick-A-Part with a trusty tape measure and start measuring. You have the old column to compare so just come as close to it as you can and you should be just fine. If the old one didn't fit just right just adjust your measurement to find an improved fit. Don't worry about the splines on the end of the column. There are only a couple of standard diameters and spline styles so Borgeson can fix you up with an adapter no matter which one you end up with.
