-   -   steering column question (http://www.hotrodders.com/forum/steering-column-question-229840.html)
rowdy51 02-21-2013 06:54 PM
Have any of ya'll ever used a circle track type steering column in a hotrod build? What would be the pros and cons?
S10xGN 02-22-2013 09:58 AM
No turn signal switch, not collapsible if that matters...
Russ
rowdy51 02-22-2013 12:07 PM
I've thought about those two things. I have a stock steering column that looks rough. I was wanting to do a Nascar type switch panel ignition so that would eliminate the key tumbler, so what could I do to get that racing look but streetable at the same time?
S10xGN 02-23-2013 10:09 AM
Go junk-yarding and find a manual floor-shift column from a pre-70 vehicle (if they still exist in scrapyards). Hmmm, prolly pretty hard to find even if they weren't all crushed. Those will not have a column switch. Or drop $250 on a cheapo column from Speedway Motors or use a race column and this clip-on turn signal switch.
Russ
OneMoreTime 02-23-2013 10:34 AM
I like the clip on steering wheel..makes getting in and out a lot easier..
Sam
Falcon Wagon 02-25-2013 07:59 PM
While we are talking about columns I have a 60 falcon 2dr wagon where is the best place to get a new column for my wagon its a 4sd Car Thanks Veach
