steering column repair
I have 72 chevy pickup with tilt automatic and the plastic shift indicator pointer broke off in the column. I have taken the steering wheel off and have tried to remove the turn signal mechanisim out after removing the three screws, but nothing seems to help in removing it or anything else in order to get to the broken pointer. Any help would be appreciated.
Need to remove the little phillips screw holding the Hazard Flasher knob on.
I think it is necessary to disconnect the battery and depress the hazards befor the switch will come out. Bryan |
The battery was disconnected before I started. The hazard button has been removed and depressed all the way in. One other thing that a mechanic friend thought, was that the jacket surrounding these parts should slide off, but we could not get it to move.
| Loose Gm Tilt Steering Wheel Moves Up And Down | fumplet | Suspension - Brakes - Steering | 10 | 05-13-2012 06:07 PM |
| GM steering column repair | willys36@aol.com | Suspension - Brakes - Steering | 11 | 08-28-2010 07:26 AM |
| '39 ford steering column and wheel | jim williams | Suspension - Brakes - Steering | 5 | 07-01-2010 09:38 PM |
| GM steering column tilt/wobble repair HELP (pics inside) | camaroguy1969 | Suspension - Brakes - Steering | 18 | 03-05-2009 12:37 AM |
| Steering Column Harness on a G-body | 1982 SS | Electrical | 2 | 07-29-2005 01:06 PM |
