Steering column replacement 90 Chevy dually - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2009, 10:46 AM
I just replaced the steering column in the truck I just bought, it was already torn into so I opted to replace it with a used one. I have a few things that don't work: windshield wipers;horn; heater control, not related to column. These things may have not worked when I bought it cause the motor was junk and would not run so I have just got it going and need some info.
Does anyone have any wiring diagrams of these items or can direct me to some I could view?
I've tried some searches but to no avail. My motor manuals don't cover the newer vehicles 86-up.
Thanks , Gerald
Old 11-12-2009, 05:47 PM
fast68's Avatar
likes chevy trucks & boobies
should be old body style and old style column '84-91
84 was first year for brights and wipers on the column in the full size trucks
theyre not too bad to work on but a little tedious regarding the brights and multifunction switch reassembly
unless wiring is chopped somewhere or something the heater blowers usually quit due to corrosion at the wire plug at the blower motor, or bad ground wire there on one of the attaching screws, check these, clean them etc.,
also sometimes the wiring plug for the relay mounted on the box under the hood gets dirty or the relay quits
also if it only has high speed then check the resistors, the wiring plug in the box, the resistors are held in place with two small screws
sometimes low and medium springs burn up on it
high speed is direct no spring
horn is probably either horns not plugged in behind the grille, or bad horn relay it is mounted to the fuese panel and square light blue color or dark green color.
try another one
if still nothing then make sure wire under steering wheel cap is connected try grounding it and see if the horn works or the relay clicks
if it clicks then its all good but the horns are bad or not connected
Old 11-13-2009, 08:40 AM
No, it could be either body style. Only the crewcab duallies were old body style through 1991. The two door and extended cab duallies used the new body style starting in 1988.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Chevy AD truck steering column question mr52pickup Suspension - Brakes - Steering 1 10-24-2008 06:45 PM
Which steering column? Cleanest, plainest marks914 Suspension - Brakes - Steering 26 04-05-2008 10:09 AM
MustangII Steering Wheel on Chevy Column smoran Interior 2 05-05-2002 08:37 AM
Chevy Tilt Steering Column James Groves Suspension - Brakes - Steering 1 11-20-2001 04:12 PM
