Steering Column (shaft) collapsed
Like always, I am learn something new daily.. Yesterday, I was working on my steering linkage, and noticed that my steering shaft was not protruding from the lower portion of the column. I honestly don't remember dropping the column, or hammering on it..And I personally pulled the column from the car which wasn't wrecked..Anyhow, after researching, I have come to the conclusion that the internal shaft of the column must have collapsed..I did pull the shaft back down into place and continued to connect my steering linkage..Now, I think I have two choices..I can either take the column apart and repair the shaft (weld it together), or just leave it.. The steering appears to operate ok as is...Any thoughts on this? The column is out of a '82 Caprice.And it is a tilt column..I have heard some say that it is ok to leave as is IF it is a tilt column, but that it is junk if it isn't a tilt column...
Thanks for the input! Last edited by scr8pin_f100; 02-23-2009 at 01:07 PM. Reason: change text |
It would help if we had some pics to go by.
Ok, so your stand on it is to just leave it alone...Has anyone else ran into this? Can those shafts separate at all in the future? Or how about abnormal wear on the joints?
Probably a bit over cautious, but this is the steering...lol Thanks for the input |
yes I am talking about the shaft..And I was thinking that the shaft was in a fixed position, until something happened to it to "collapse" it, thus popping the little plastic keeper...Trust me, I'm liking the fact that it looks like I woun't have to replace my column..I just wanted to ensure that everything was still ok with it..I had been told many things about it..both good and bad...
The column is fine to use, the shaft has a nylon pin that holds the shaft from falling out on the assembly line, you probably broke it pulling it off the rag joint, the shaft is made to collapse in an accident so the shaft won't come thru the steering wheel and pierce your chest! The normal streetrod application is not a straight mounting,but rather an angle to the floorboard to a universal joint, which ,in theory, would negate the need for the collapsible shaft, but it's good insurance anyway!
| Which steering column? Cleanest, plainest | marks914 | Suspension - Brakes - Steering | 26 | 04-05-2008 10:09 AM |
| Steering column ID | tgifford5 | Suspension - Brakes - Steering | 1 | 09-09-2007 08:30 PM |
| steering column help needed | stea | Suspension - Brakes - Steering | 5 | 01-11-2005 03:19 PM |
| G.M. steering column hookup ? | jcarter | Suspension - Brakes - Steering | 2 | 01-01-2004 03:35 PM |
| shortening the steering column | smoran | Interior | 3 | 05-02-2002 06:38 PM |
