Steering column wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2007, 08:33 PM
I have a used tilt steering column out of a Chevy van. The wiring exits from the end of the tapered tube that the shift lever is attached to and moves with. These wires then hang loose down the column. I think the wires were removed from column when turn signal switch was replaced and this was the easiest way to reinstall them. Is this wiring supposed to continue down the inside of the steering column hidden from view? I am going to install this in my 39 Ford and don't want these wires to show.
Thanks for any information.
Ken
Old 03-08-2007, 10:10 AM
powerrodsmike's Avatar
Wiki Edits: 161
The aftermarket columns run the wires inside, the stockers run the wire outside, and have various covers that snaps over the wires, dependent on the application.
There are a couple of companies making covers for those, there was one cheap one that was causing fires, but I can't remember which one.
I know Speedway makes a plastic cover, part # 910-32601 and I think that one is OK.
http://www.speedwaymotors.com/p/2050...emNo=910-32601
Hope this helps,
Mikey
BE different....ACT normal.
Old 03-08-2007, 10:42 AM
Thanks Mikey, I guess that GM was not thinking of hot rods when they designed the wire routing for their steering columns.
Ken
90 Caddy steering column wiring. lakota Electrical 4 03-05-2007 07:45 PM
Steering Column Wiring loiselle Electrical 3 05-16-2006 11:08 PM
wiring diagram for 1987 S10 (steering column rodrigjose Electrical 3 02-04-2005 07:12 PM
steering column + new wiring stea Suspension - Brakes - Steering 2 12-13-2003 08:08 PM
Steering Column wiring fred56 Electrical 6 12-07-2002 11:16 AM
