I acquired a GM steering column but the wiring harness has been cut. How do I go about finding out what wire is what? Where can I get a wiring diagram for it without knowing the end application?
Thanks for your help. |
can you tell what car line its from? chevy, olds, etc. if you can tell that and guess the era from its appearence[early 70s, late80s.] try to look up a diagram from a random car from your best guess. the color code and wire positions shouldn't vary to much from car to car, this should give you a basic start. good luck.
my 79 3/4 trucks was
as per haynes manualnotchiltons)white: STOP LIGHT SWITCH; DK GRN: RT RR LAP; YEL: LT RR LP; PPL: SIG FLSR; BRN: HAZ FLSR; DK BLU: RT FT LP; LT BLU: LT FT LP; BLK: HORN. THIS MAY BE IT OR IT MAY NOT BE. TO BE OR NOT TO BE. THAT AINT THE QUESTION. FOR TURN SIGNALS, HAZARD FLASHER, HORN ALL IN COLUMN. IT MAY MATTER TO YOU OR NOT, BUT THIS ELIMINATES SEPERATE TURN SIGNALS AND BRAKE LIGHTS CONTROL, I MEAN IF A 3 PRONG TAIL LIGHT IS A BRAKE LIGHT IT WILL ALSO ACT AS A T/S. I WANTED ORANGE T/Ss AND RED BRAKES, BUT IF I DID THIS I WOULD HAVE MY ORANGE LIGHT GO ON WITH THE BRAKES. THE ONLY WAY I COULD FIGURE OUT TO DO IT WAS TO TIE IT IN TO THE FRONT T/S ONLY. I SHOULD KNOW THESE BY NOW, BUT I STILL AINT NO CAR 'LEC-TRICIAN! |
Howdy all
Al here with AutoReWire.com. Haven't been around much cuz' I've been busier than a cat covering up you know what. Here is some more information that might help: GM COLUMN PLUGS TURN SIGNAL CONNECTOR Late 60's, 70's and 80's Gauge Color Desc. Plug Marking 20 Black Key Alarm E 20 Pnk Dbl Blk strp Key Alarm F 20 Black Horn G 18 Lt.Blue LF Turn Signal H 18 Dark.Blue RF Turn Signal J 14 Brown Hazard Flasher K 14 Purple Turn Flasher L 16 Yellow LR Turn Signal M 16 Dark Green RR Turn Signal N 14 White Stop Lamp Switch P IGNITION SWITCH If it has one. Pur/Wht Ignition Start Pnk Ignition Coil Brn Accessory Fuse at Fuse Panel Orn Ignition Switched Bus at Fuse Panel Red Battery Hot Lead The wiring on late '40's and early '50's Chevys and Pontiac will be different at the rear lights and the horn wire. Horn Dark Green LF Turn Signal Lt. Blue RF Turn Signal/Stop Dark Blue LR Turn Signal/Stop Pink RR Turn Signal/Stop Violet Column to Stop Switch White Turn Flasher Yellow Mid '60's Chevy's got wired weird Most Buicks through the early 60's Horn Lt Blue LF Turn Signal Dk. Green RF Turn Signal/Stop Lt. Green LR Turn Signal/Stop Lt. Green w/Blk RR Turn Signal/Stop Dk. Green w/Wht Column to Stop Switch White Flasher Pink Flasher Gray When installing a late GM Column replace the three prong flasher with a two prong and use the Pink Wire. Wire to the Purple wire in the New Column. Later, al Al@AutoReWire.com [ December 06, 2002: Message edited by: AutoReWire ]</p> |
Thanks Al - You hit the nail on the head with your information. Now I can rest in peace.
