steering damper for 65 Chevelle Help find?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 04:46 PM
Hey there
on my old 65 chevelle I have power steering old school,
you know you can almost spin the wheel when turning its so
easy. I want to put a steering damper on it, does one exist for this
thing??? This old school steering gets dangerous when your reacting
to the back coming out (posi) as hard as you try the wheel is so easy,
over steer is common. through first, second with the back end wanting
to go sidewise I think a dmaper would really help. Don't want to do rack
pinion.
Thoughts??
thanks in advance
Old 12-27-2011, 06:06 PM
Just replace the steering box with one from a 90s Jeep Cherokee. It has a 12 to 1 ratio, and bolts in outside of the rag joint and hoses. You can get the rag joint from Borgesen, and the hose adapters from NAPA in the Weatherhead catalog.
I know of no steering damper that is a bolt on.
steering damper chuck bell Suspension - Brakes - Steering 2 09-20-2010 10:45 AM
Need help find rear brake backing plates for Chevelle cutterbond Suspension - Brakes - Steering 4 05-28-2010 03:54 PM
trying to find vin on 68 chevelle i have all numbers but the last four princess1963 Hotrodding Basics 7 01-15-2010 08:25 AM
Steering 101: Where to find info? marks914 Suspension - Brakes - Steering 3 01-23-2008 01:24 PM
Steering shaft boot - where to find one? 69ChevelleAddict Suspension - Brakes - Steering 2 10-06-2006 05:50 PM
