Steering gear box for 1954ford p/u - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2010, 01:07 PM
Hi Im needing help and advice on what steering column and gear box will fit and work the best on my 1954 Ford p/u . It needs to be power steering. My engine is a 302 and already has the power steering pump on it .
Old 01-31-2010, 04:48 PM
On of the newer steering boxes with 3 bolt pattern could be made to fit your truck frame. I would look at ford steering boxes at the part store and check the bolt pattern. I would find one from a similar year vehicle as your motor so the pump flow and pressure matches up...
Need some help sorting out tranny ratios and rear end ratios firstgear Transmission - Rearend 3 11-06-2008 07:39 AM
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
*Help* 72 Chevy P/U with Step Side Box *Help* Mustangsaly General Rodding Tech 8 01-20-2006 08:07 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
steering box blew its seals....78 nova snod83 Suspension - Brakes - Steering 7 11-01-2005 11:52 PM
