Steering gearbox replacement-Vega vs F-1?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2011, 05:29 AM
Of the two steering gear boxes which do you think is the better choice and why? Thanks for the help. I'm trying to make a decision and your valued input would be helpful.
Old 04-28-2011, 07:18 AM
Wiki Edits: 27
different design.
The vega is designed to work as a cross steer, it's mounted near the front axle. The pick up gear box was mounted along side the engine and is a front to back steer. it depends on which design you want to use.
Old 04-28-2011, 10:01 PM
Vega vs F 1 steering gear box
Thanks. I have both here in my shop. I did study the ratio's too and the Vega has a quicker turn. Either will keep me busy for a few evenings.
Normbc9
Old 04-29-2011, 06:13 AM
Wiki Edits: 27
adjustable steering
I built my first T bucket 50 years ago. I used the stock pieces from a 39 ford, It was 5 turns lock to lock. It was way to slow steering. I couldn't turn the steering wheel fast enought to get out of a slide when playing in the dirt. I looked at an old dirt modified racer and it had a home made steering pitman arm and spindle mounted drag link arm . They had several tappered holes in each one so they had plenty of adjustment. The next few cars I built I did the same thing. until I decided how many steering wheel turns I wanted for full left to full right lock to lock for later builds.
Old 04-29-2011, 06:32 AM
I have owned 32 Fords with the F-1 box and the Vega box. I much prefer the Vega box. Easier, cleaner to do and drove better.
Just my opinion.
How to replace a steering gearbox seal..... STATUTORY GRAPE Suspension - Brakes - Steering 2 08-25-2008 11:08 AM
Cross steering (vega gearbox) tbucketal Suspension - Brakes - Steering 6 08-29-2007 08:42 PM
Vega Steering Box Frisco Suspension - Brakes - Steering 2 09-29-2005 08:14 AM
vega steering box 101... b.c.kid Suspension - Brakes - Steering 2 12-06-2004 07:51 PM
steering gearbox bobby r. smith Suspension - Brakes - Steering 0 11-05-2002 08:12 AM
