Steering Lash Adjustment Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2005, 08:30 PM
I'm doing a complete overhaul on the steering box on my '62 Corvette. I've installed all new bearings, races, worm and sector gear. Everything went smoothly until I tried to adjust the last to get the correct pull in lbs over the high point. The lash adjuster screw is all the way out and when I tighten the four bolts for the lash cover it tightens the lash too much and it takes too much pull on the wheel to get it over the high spot. If I back off a little on the four bolts it is just enough to back off the lash and the effort to pull the wheel over the high spot. Any ideas on how to correct this? Only solution I can come up with is to make a metal shim to space the cover out just a little so I can get the proper lash adjustment,would this be a correct solution?
Everything turns smoothly up to the point of tightening the 4 bolts on the lash cover and the screw is out all the way.
Old 12-30-2005, 09:23 AM
Last journal entry: Cooling...
Lash
Is it possible that the rack gear is installed upside down? The teeth usually have quite a bit of taper, which would raise the sector gear if it were installed upside down. In my experience, the sector drops quite a ways down into the box before zero lash. Just a guess, good luck.
power steering Paco Suspension - Brakes - Steering 9 10-31-2006 07:02 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 02:06 PM
79 Caddie Steering Problem Jim Reid Suspension - Brakes - Steering 1 07-02-2004 07:26 AM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 10:03 PM
350, valve lash adjustment kenrodp Engine 1 11-13-2001 07:14 PM
