steering links - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2002, 10:43 AM
Post steering links
I AM USEING CROSS STEERING ON THE 34 FORD VEGA BOX , WHICH IS BETTER , STEERING ARM ON PASSENGER SIDE WITH 2 HOLES OR THE TIE ROD WITH HOLE IN THE END TO WHICH STREEING LINK TIES TO?? ALSO DOES THE STEERING LINK HAVE TO BE PARRELLEL TO CROSS LINK
Old 10-06-2002, 11:26 AM
Post
I am also using a Vega box on my 1932 Ford Roadster. I prefer the spindle with the 2 holes in it to the tie rod adapter with the extra hole. That's the way Ford did it.
I had to buy a set of lowered bolt on steering arms for my spindles because of the 4 bar set up front suspenion interfered with the steering arm to spindle clearance. The arms lowered the bar that runs from spindle to spindle and gave me more room for the Harmonic balancer to clear. I have a SBC.
The two bars do not have to be parallel.
With cross steering, a panhard bar is a very good idea. I have one.
Old 10-06-2002, 05:49 PM
New Member
Post
do any of you know where i can get a steering box(rack & pinion) for a formula 500 or 1600 car?
