Steering Post Location on 29 Ford Highboy - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2014, 12:10 PM
Fellas, I have a 29 Ford Highboy Roadster. I purchased it as a completed hot rod. The steering column and wheel seem to be located too far to the left. The seat position is in proper location and when you look at it from the back, the steering wheel is at least 3 to 4 inches to the left. A friend of mine has a 28 highboy and when I get in his and I am a big guy, I slide in easily. On mine, I can't slide in at all, so I have to stand up to get around the steering wheel which also can be tilted. Question is, can I just relocated the mount, which is an aluminum one over 3 to 4 inches without having to modify the knuckle steering system. Or do I have to modify the universal knuckle to accommodate the extra 3 to 4 inches of movement. Any help on this would really be appreciated. Thanks The Spudman
Old 02-07-2014, 11:35 PM
you may have to modify the length of the steering shaft. depending on the angle of the original shaft it may impede total movement of the u-joint. the more acute the angle, the less likely you are to trim the shaft. depending on how the column is mounted, moving it laterally may or may not be difficult.
Old 02-08-2014, 06:18 AM
Irelands child's Avatar
Ouch!! It sounds like whoever built the car had an awakening after everything else was done. Your best bet - pull everything out and start over. By just moving the column over, you change u-joint angles and then angle the actual wheel in relation to the dash - and still be uncomfortable to drive. You will need to consider your seating position and your actual body size for the best location. Then too is the actual wheel tilting adjustments and their limits. Not a fun job, but it sure can make driving the car a lot more fun. The engine in my '31 is set back a couple inches more then usual so it can be 'interesting' to figure out the right place and angles for steering columns. Here are a couple of photos for you to judge where thing should be since Model A chassis are all virtually the same:
BUT IT IS IN THE CORRECT PLACE
Dave W
Irelands child
Old 02-08-2014, 08:51 AM
Wiki Edits: 27
Irelands child build picts
Dave has posted a lot of picts over the years of his A roadster, (I have an 28 A roadster that needs a complete rebuild) He has added a lot to steel tubing to beef up the body structure.
A question for you Dave . is there a build journal of your roadster. ?
Old 02-08-2014, 09:19 AM
Way back I just barely started a journal, but when I went to make changes if I went a different direction, the site wouldn't let me, so abandoned it. I'll answer anyone's questions on an 'A' build as to what worked (or didn't) for me, though either via the normal thread route or PM.
Dave W
Irelands child
Old 02-08-2014, 10:10 PM
Dave, thanks for the pictures and reply. I am going to take your advise and start over and take it all apart. It is a fiberglass body and will have to be pretty precise. Right now the steering wheel is aprox. 1 1/2" away from the door and the turn lever is almost touching the door. I want to make it right so I can easily get in the car and also make it safe instead of angled while sitting. I don't know what the guy was thinking by not centering the wheel to the seat. Its mounted really well and the steering is precise when going down the road just to far over. I would like to thank you for the info. The Spudman
Old 02-09-2014, 03:53 AM
da34guy's Avatar
Good thinkin Spudman,
Just went through the same thing on a 32.
Have no clue how the original builder drove it for 900 miles.
Double D shaft was hittin the headers.
Yanked it all out and redid it.
First patched the hole in the firewall, then re stabbed it in the proper place, ended up where everything cleared, steering wheel was centered, and all I had to modify was cut 7/8 " off the DD shaft and move the column drop down 1"
3 hr fix.
Name:	2014 3 winder 018.jpg
Old 02-09-2014, 06:54 AM
Wiki Edits: 27
reinfircing a glass body.
I don't know how much reinforcement there is in your glass body. The last T bucket glass body I built I bent some 1 in 090 wall sq tubing into an inverted U to bolt to the frame and up each side and across the bottom of the instrument panel for steering column support. I used my harbor freight pipe bender with out the top rollers, got it as close to the skin on the sides as possible.
29 Ford Highboy Roadster spudman49 Introduce Yourself 14 12-16-2013 01:59 PM
28 Ford Tudor Highboy Build Boxc@r Projects/Builds/My Ride 9 07-08-2013 06:13 PM
30 ford highboy rebuild. davey nuts&bolts Introduce Yourself 1 03-22-2011 07:15 PM
29 highboy, new engine location pcoghlan General Rodding Tech 9 07-20-2009 10:47 AM
Finishing 31 ford coupe highboy coupe 31 Introduce Yourself 6 05-23-2008 11:15 AM
