Steering pulsation when turning right - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2009, 09:46 AM
My 67 Mustang Coupe is driving again. All steering components are brand new and everything is tightened to spec. I've done the granada disc brake swap and converted my PS to MS with one of the control valve delete adapters and I have the good "roller" (gusher bearing) idler arm.
I am getting a pulsation when turning right only. Doesn't do it when straight or turning left. And it doesn't have to be an actual turn, even if the steering wheel is turning towards the right "riding" a road rut it will do it.
I first thought wheel bearings not properly preloaded because it's only doing it on one side, so I checked them both and both are good (and brand new to boot)...
I am at a loss as everything is new (save for the steering box) and tight.
Any thoughts guys?
Old 07-23-2009, 08:01 AM
67Mustang Al.'s Avatar
Steering feed back.
I have all the steering components out of my 67 coupe (with power steer) and have seal kits etc. coming from L.A. Mustang Country. I have had the steering box to pieces and the information i have found tells me that the sector shaft in the box when turned from full lock to lock should be tighter when the car is steering straight ahead(sector shaft in the centre position) so as not to wander left or right. When the sector shaft goes past the "straight ahead "position left or right, there is more clearance between the worm and the sector shaft. If there is too much wear in the sector shaft it will loosen up when you turn right or left depending which side is worn. As it is the only thing you have not renewed it is possible it could be the box sector shaft and worm are worn.The "end float " on the sector shaft is critical and needs to be checked . The pitman arm needs to be disconnected to enable you to set it up correctily. I googled "67Mustang Steering Adjustment and found plenty of info.
It sounds as if you have eliminated all possibilities. I have also seen that happen when the power steering fluid becomes aerated.
My neighbour chased a pwr. steer problem on his BMW 7 series for months and found an offcut of a rubber hose sucked down into the pressure line. The steering was "squealing like a pig" when turned from lock to lock.
Cheers
Al
Old 07-23-2009, 09:19 AM
Great information, thank you.
I have a Model A Pickup to build, have Lots of questions. 88lowrider General Rodding Tech 103 05-14-2009 09:46 AM
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
Grinding sound when turning steering wheel? dhomsey General Rodding Tech 11 12-14-2006 01:18 PM
79 Ranchero Key stopped turning ignition steering lock! Crappie/Smitty Electrical 5 10-17-2005 07:31 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
