steering pump id help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2009, 08:53 PM
Anyone have any idea of what pump this is ? It's on my 37 chevy small block build. Someone told me maybe saginaw ? Also, looking for opinion, what's best junkyard steering column (year and model) to look for - easy swap I hope, I have floor manual shift, would like a tilt and prefer gm for wiring hook up.. Thanks
Old 06-27-2009, 01:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Look it over for a stylized "S" on it somewhere. But it definitely resembles a Saginaw.
You pretty much answered your own question regarding the column. Check out any of the A, B, G, F, H or rear drive X body cars. Others including pick ups and vans might work as well, it depends on what size you are looking for.
Steering wheels can be swapped between many of the GM lines. Look for the ignition switch and neutral switch to be column mounted to save the trouble of wiring them separately, and grab the loom while you're at it. Try to find a column w/the keys included.
Power steering pump on blown motor Marcus Engine 14 05-16-2008 01:10 AM
installing power steering using gm pump and t/bird Rack Bad Rat Suspension - Brakes - Steering 5 03-22-2008 12:51 PM
1971 chevy 350 power steering pump colincamaro Suspension - Brakes - Steering 10 12-27-2006 01:14 AM
Mustang 2 Power steering pump nugget Suspension - Brakes - Steering 1 10-05-2004 12:57 AM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
