steering pumps - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2011, 02:27 AM
steering pumps
How well does a vega steering pump work on n aearly ford chassis?
Old 09-22-2011, 03:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
They are Saganaw pumps, whether the valving will be correct for your set-up is the question. Do you have any details of what steering box, etc. you want to use- is it a Vega box, too?
Old 09-22-2011, 04:51 PM
steering pumps
I have sent the numbers on it to my local ford dealer to find the year and application.
This in not a power steering unit. I think I would rather have a power steering unit in it anyway. Any suggestions?
Old 09-22-2011, 05:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm a bit confused here.
Are you talking about the steering gear box or the steering PUMP? Why would you send GM numbers to Ford?
In any event, if you're building this from scratch- as in you can do whatever you want- why not look into using a rack and pinion steering set-up (Example)? Every rod shop has their version of the venerable Pinto/MII rack steering set-up. They can be had complete from hub to hub or just the individual parts that can be cobbled together to make your own.
Check out Chapter 3. The whole book will help you for that matter.
Old 09-22-2011, 09:46 PM
steering pumps
I'm sorry I confused you, it is a steering box that I found. I was told that it is out of a maverick, but I don't know for sure.
LS1 engine accessories: Any other power steering pumps work with the Camaro setup? grobb284 Engine 1 07-21-2009 06:53 AM
oil pumps 454cutlass86 Hotrodding Basics 3 03-12-2009 09:06 AM
oil pumps 101 k-star Engine 26 05-22-2006 11:00 PM
Gas Pumps Kevin45 Hotrodders' Lounge 4 10-05-2002 04:56 PM
oil pumps truckin chuk Engine 4 03-22-2002 05:22 PM
