Steering Question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2007, 11:22 AM
Steering Question?
I have put a chevy engine into a '87 Mazda pickup. The power steering pressure line runs from the pump across the lower radiator support and back to the steering sector, just a loop. Would it ok to just run the gm pressure line straight to the sector from the pump (about 8"), or do I need to keep the loop in the line? It sure would be easier to run both lines about 8" or so, and be done with that part. Thanks for any infor.
Old 09-17-2007, 11:42 AM
cboy's Avatar
Last journal entry: Finished
All I can say is I've bent, shaped, distorted, angled, and gerryrigged power steering hard lines all over the place with no negative consequences (although I'm sure there can always be a first time.) Keep in mind, however, I'm just a shade tree builder and would defer to the expertise of any of you power steering gurus on board.
Always learning...and sharing what I've learned.
Old 09-17-2007, 11:43 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
That loop is probably for cooling.
Old 09-17-2007, 07:37 PM
I think you right Highrise, I wandered throught the salvage yard this afternoon on the look out for some lines. I noticed that some ford pickups had a similar routing. I am also thinking that cooling could just about be the only reason. Thanks, both, for the reply.
Power steering whine/lack of assist question '45 Ford Suspension - Brakes - Steering 7 07-05-2007 02:05 PM
Power steering question chrisflock Suspension - Brakes - Steering 4 02-19-2006 02:31 PM
Steering Question smoke_eater Suspension - Brakes - Steering 4 12-04-2005 09:41 AM
A steering column question. Bluepen Suspension - Brakes - Steering 11 03-20-2005 10:10 AM
Steering Wheel Adapters Question horvath Interior 17 06-26-2004 06:50 PM
