Steering rack question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2004, 10:26 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
I took my Jag out the other day for a nice long drive before I had to get it smogged. I know the rack has a leak so the system was low on fluid. I refilled the PS Pump and backed it down the driveway, man the steering wheel was hard to turn. If I'm driving at speed the thing turns great but at idle it really hard. Could there be air in the system? OR what causes this condition?
Regards
Mark
Old 01-07-2004, 06:43 PM
adtkart@aol.com
Could possibly have air in the system. Could also be that the belt is slipping. You also might have a pump that is going out, from being run low for too long. The higher RPM at highway speeds may be giving you enough pressure, where the lower speeds you don't have it.
Just my guess.
Old 01-09-2004, 08:12 AM
rally4x4racer's Avatar
beer and time
Last journal entry: right after paint
hey jag!
im not too familiar with jags, but do you have a brake booster running off the pumps vacuum?
if you want to try to bleed it also ( im not sure if this is done with the psp (pwr string pmp) cap on or off )
I imagine that may depend on if you do it with the vehicle running or not.
I did mine with it off then with it running and the cap on.
ATW (all the way) left and ATW right about 20 reps and check level.
you might flush the box too and refill/bleed.
im sure this isnt much help, but possibly something to look into.
