Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Steering shaft
Thread: Steering shaft
Old 01-17-2006, 03:07 PM
enjenjo enjenjo is offline
Russ, I think the problem was caused by the distance from the lower bearing on the column, to the upper U joint. But as you said, the shaft support fixed it, so it's all good.
