Steering shaft clearances - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2011, 11:12 AM
Hi everyone,
I am mocking up the steering shaft in the engine compartment now using Borgeson U-joints & shafts. What is the general recommendations for clearance between the shaft/u-joints & any frame or engine components ? Also, these are stainless steel products, so will they blue or discolor any if they are close to the headers ? Any additional clearance for the shaft to the headers ?
Thanks,
Mike.
Old 07-20-2011, 08:44 AM
S10xGN's Avatar
Gotta love a turbo!
Mike, a lot will depend on your motor mounts. As you can see here, clearance between the shaft and header pipes are around 3/8". But, I also have urethane mounts that move very little. The car has since been finished and the shaft has been coated with standard grade automotive paint. There is no sign of any discoloration or burning, but that could also be affected by the header coating...
Russ
Old 07-20-2011, 06:35 PM
steering shaft clearances
Russ,
Thanks a bunch for your comments. I also have polyurethane mounts, so will shoot for 3/8 min around the engine area.
Mike
steering shaft charts? raj4851 Suspension - Brakes - Steering 2 10-08-2009 08:02 PM
What steering input shaft is this? marks914 Suspension - Brakes - Steering 5 01-28-2008 08:45 PM
Steering Shaft Question Quarter Flash Suspension - Brakes - Steering 3 09-19-2006 01:36 PM
Steering shaft seal 1939d2/s10 Suspension - Brakes - Steering 3 08-12-2006 08:25 PM
Steering shaft chiss Suspension - Brakes - Steering 12 01-17-2006 04:03 PM
