Steering shaft - header clearance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2011, 01:51 AM
staleg's Avatar
Last journal entry: Hand brake
Hi
I have an honest 3/16" clearance between the header and the steering shaft.
Is that enough?
The header pipe is kind of running parallell with the steering shaft in that area, so making a single dent in the pipe will not help (maybe I could carefully flatten the pipe a little in the entire length instead?)
The motor is a Chevy small block and the engine mounts are new and of the universal cushion type with a bolt thru.
Old 03-11-2011, 03:10 AM
ericnova72's Avatar
More for Less Racer
That should be plenty of clearance. Engine torque pulls the engine away from that side. I've seen them so close you could barely slide a sheet of paper between the shaft and the header pipe and there was no problem.
Old 03-11-2011, 06:22 AM
staleg's Avatar
Great! Thanks
Old 03-11-2011, 09:12 AM
Irelands child's Avatar
Less then .25 inch and no problem
Dave W
Irelands child
Old 03-11-2011, 04:53 PM
302 Z28's Avatar
Mine is about like Dave's and I have had no problem either.
Vince
Old 03-11-2011, 07:08 PM
Dave W
One thing I didn't mention - I couldn't use the long set screws and lock nuts so I replaced them with shorter sets, drilled a spot about .062-.125 deep in the shaft splines, used high strength Loc-Tite and lightly punched 2 places to prevent back out but not enough so it would be impossible to remove the u-joint.
Dave W
Irelands child
distributor to oil pump shaft clearance CosmikDebris Engine 4 01-22-2011 06:41 PM
Header clearance 4.3 v6 tbi 91 Astro vickraft Engine 0 06-29-2010 06:08 AM
header plug clearance pena0724 Engine 11 08-09-2009 05:26 AM
Excess oil pump shaft clearance HP52TA Engine 2 03-15-2009 09:54 AM
header clearance ? legionlleh Engine 2 02-24-2007 10:56 PM
