steering shaft mock up, what ya think? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2013, 04:36 PM
Proposed route for my steering shaft... any ideas? How does it look? Thinking about the ujoint being too close to the header and may cook the lube out of the bearings? Heat shield may be in order. Support bearing will be in the motor support coming off the frame.
Old 10-09-2013, 06:08 PM
astroracer's Avatar
If you are putting in a support bearing I would suggest going to a double u-joint in the middle. Use your single up near the bottom of the column. That would let the shaft kick down and back a bit to get the u-joint out of the heat zone.
Here are some pics of what I had to do on my van build. The corvette rack is kicked forward about 35 degrees to get the angles I needed for joint articulation. The upper joint is a double to get it around the corner.
The mid bearing mount is bolted through the firewall and plated on the inside also.
Another option would be to have the headers Jet Hot coated. That would cut down on the radiated heat and also keep the engine compartment a bit cooler.
Mark
steering shaft coupler ramman1500 Suspension - Brakes - Steering 1 01-13-2013 04:29 PM
help with steering shaft Pupsvette76 Suspension - Brakes - Steering 8 12-17-2011 06:30 PM
Steering shaft clearances Hot Rod Mike Suspension - Brakes - Steering 2 07-20-2011 06:35 PM
Steering shaft seal 1939d2/s10 Suspension - Brakes - Steering 3 08-12-2006 08:25 PM
Steering shaft chiss Suspension - Brakes - Steering 12 01-17-2006 04:03 PM
