Steering Shaft Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2006, 11:09 AM
Last journal entry: Albany Oregon Show
My question is concerning a drag strip only 1980 Monza. The steering shaft that links the steering column and the pinto rack. I have a length of 1/2" dia by 1/16" wall tubing (mild steel) and was thinking I could cut a length of this tubing and weld two universals on and have a steering shaft. The critic in me says the tubing is not strong enough. What do you guys think?
Bob
Old 09-19-2006, 01:06 PM
Don Meyer's Avatar
You are right.....1/2" thin wall seamed mild steel tubing would not be strong enough.
Don
Old 09-19-2006, 01:24 PM
powerrodsmike's Avatar
Wiki Edits: 161
Don Meyer is right. Bad Idea to use that mild steel small OD thinwall.
If you are really trying to save weight......
Morrison sells some steering columns using 3/4 od X .058" 4130 chrome moly tubing. That would be the MINIMUM that I would use.
I would TIG weld a splined adapter to the tubing and then fix a splined U-joint to the adapter with set screws.
Double D adapters/ U-joints would work too.
Don't weld on u joints.
Later, mikey
BE different....ACT normal.
Old 09-19-2006, 01:36 PM
Steering Shaft
Thanks for the Morrison tip I think I will go that way. At 150 mph steering is good! Too the best of my recollection anyway.
Bob
1986 s-10 truck steering shaft linkage worn? fumplet Suspension - Brakes - Steering 4 07-21-2006 10:42 PM
universal steering shaft joints 49dream Suspension - Brakes - Steering 1 03-15-2006 07:09 PM
Steering Question smoke_eater Suspension - Brakes - Steering 4 12-04-2005 09:41 AM
Dumb Power Steering Question... Mike_82 Suspension - Brakes - Steering 1 03-28-2005 10:43 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
