Steering shaft seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2006, 02:05 PM
1939d2/s10's Avatar
Steering shaft seal
Hey guys,my buddy is building a 30 Ford coupe.He has mounted the steering column under the dash,it does not use a floormount.His upper Ujoint connects to the steering shaft from the column and a 1" diam shaft continues thru the floorboard and attaches to another Ujoint .What he cannot find is what to use on the floorboard for the 1" shaft to go through.Any ideas ? Thanks Johnny
Old 08-12-2006, 06:24 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I was thinking you might use a standard support bearing near the floor on the shaft that goes through the floor, but I have not seen a support bearing for a 1" shaft. Every one I've seen is for a 3/4" shaft.
I assume the steering column does not reach to the floor? If so, how far from the floor is the bottom of the shaft? More details would be very helpful.
Old 08-12-2006, 07:19 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Go to Borgeson. www.borgeson.com They have support bearings all sizes as well as steering column floor mounts etc. Anything to do with steering...they got it.
Old 08-12-2006, 08:25 PM
The Borgeson catalog only contains 3/4" support bearings. Wouldn't hurt to call and ask if they have other sizes as an off-catalog item.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
rear oil seal help alrobjr Engine 5 01-24-2006 07:12 AM
cure for worn steering shaft? cboy Suspension - Brakes - Steering 2 04-07-2004 09:21 AM
Just removed shift shaft seal and have a ? hlweyl Transmission - Rearend 4 10-23-2003 10:06 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
