-   -   steering stabilizer install (http://www.hotrodders.com/forum/steering-stabilizer-install-235285.html)
lowflyer 07-25-2013 01:04 PM
Quick question, on installing a steering stabilizer.
As one end is bolted to the center of the center link (tie rod,) does the other end need to be bolted to the frame?
On my '29 Coupe, the outer end of the stabilizer is bolted to a clamp around the lower bar that locates my tube axle.
Would this cause any problems, or should I put a bracket on the frame?
