steering is toooooo quick - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2011, 04:49 PM
I have to slow down the over responsive steering in my 1951 chevy p/u. I have a Mustang II with a power rack----general motors power steering pump. It is extremely quick and to the point that one could put this vehicle in the ditch if they were not careful. Is there a way to slow this quick steering down?
Old 07-28-2011, 04:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You need to post this question in the Suspension - Brakes - Steering ,
just go to the bulletin board and scroll down to the section you need.
Cole
Old 07-28-2011, 08:48 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Originally Posted by rdsieveke@gmail.com
I have to slow down the over responsive steering in my 1951 Chevy p/u. I have a Mustang II with a power rack----general motors power steering pump. It is extremely quick and to the point that one could put this vehicle in the ditch if they were not careful. Is there a way to slow this quick steering down?
As far as I know the pressure from a GM pump is to high... You have to fix the pressure I want to say they sell the right valve to fix it....
Another thing to check is you Caster... To see what they have it set at...
The first thing I would do is fix the pump...I think someone will post what to do with it.... I never ran much power steering on my hot rods... Just heard a few people talking about it.. Good luck..
Old 07-28-2011, 10:10 PM
Wiki Edits: 49
Borgeson makes a Pressure Reduction Kit for the GM pump. It's under $20 and will solve your problem.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Old 07-29-2011, 09:45 AM
Thanks Centerline... That's what I was trying to say...
NOW!!!! GET BACK IN YOUR SHOP CL !!!!!!! LOL
Old 07-30-2011, 01:41 PM
pnt4u2's Avatar
Correcting the "Twitch"
The problem you are encountering is called a "twitch". Too much VOLUME! Mustang rack uses 2 GPM where as a GM p/s pump generates 3-3.7 GPM. I just changed my FLOW CONTROL VALVE out. It will change the rate from 3 GPM to the 2 GPM needed. Speedway Motors has the best price I have found. Less than $20 plus shipping. They screw into the back of the power steering pump and the pressure line screws into it. Easy as pie! Verify with www.GOTTASHOW.com products. They offer the same valve w/explanation. Good luck.
Old 07-30-2011, 01:56 PM
I have operated two street rods with MII power racks with GM pumps for over a hundred thousand miles and have not experienced your problem. I did use a kit in one of the pumps when I rebuilt the truck and it made it quieter, but could tell very little difference in performance. When you do modify your pump and find it is still overreactive, set your toe in to the max MII specs and your problem should be solved.
Trees
Quick Power Steering Q 454headache Suspension - Brakes - Steering 2 11-11-2009 10:22 AM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 03:34 AM
Steering box (quick or stock?) stinky jinx Suspension - Brakes - Steering 2 07-29-2004 10:15 PM
My steering dont work. Need Help Quick. 1973ChevroletNova Engine 2 03-17-2004 04:52 AM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 03:59 AM
