steering u-joint donor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2008, 08:08 PM
Cape Cod Bob's Avatar
I need to hook up my 74 MII rack (power) to my Buick column. What likely donor cars found at the boneyard are likely to have a u-joint for the rack. And also a DD both ends u-joint.?
Old 10-28-2008, 08:36 PM
I'm thinking astros had them, 05ish Bonnevilles also, but some made noise and were replaced with rag joints by GM.
Old 10-29-2008, 07:57 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
Late model Firebirds and Camaros as well as Astro vans and Safari vans used a u-joint intermediate shaft which might work for your. With something as important as steering though the purchase of new joints from Flaming River or Borgeson might be money well spent. The joints are typically $75-80.
Better to be safe on the road.
Old 10-29-2008, 08:23 AM
powerrodsmike's Avatar
Wiki Edits: 161
Check out the wiki article on that subject.
http://www.crankshaftcoalition.com/w...junkyard_parts
If you can add info to the article, feel free to do so.
Later, mikey
BE different....ACT normal.
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
Steering box/Coupler (rag joint) Questions RObs71Nova Suspension - Brakes - Steering 1 10-26-2004 11:34 PM
Replace Steering U joint Dave E Shank Suspension - Brakes - Steering 1 08-13-2004 05:51 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
