Steering u joint phasing/turn cam synchronizing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2010, 10:21 PM
ok
so flaming river 2 inch column with 3/4 dd end. I cant get the joints to be in phase. ( forks in line) and 11 oclock on the cam. Someone talk me through this please..
More info
ford 26 spline to 3/4 dd ( rack end)
3/4 dd to 3/4 dd into steering column
when u joints are in phase cam is at 2 oclock
also what do i do with steering column to dd shaft. Do i drill and put a bolt through it?? or does it just sit there????? oh and the angle seems to be at about 25 degree
Old 03-12-2010, 03:07 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Go to this link and do some reading.
http://www.woodwardsteering.com/imag...%20100-105.pdf
Old 03-12-2010, 04:22 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
This is the procedure I use when installing steering linkage. Before the linkage is installed, center the steering column so the tab (bump) that cancels the turn signals is straight up at 12 o'clock. Center the steering rack by moving the tires lock to lock and counting the number of turns on the input shaft of the rack. Divide the number of turns by 2 and then move the rack back to that number of turns. (4 turns lock to lock puts it on center in 2 turns for example). Since you have a DD shaft, the u-joints will automatically be installed in phase when you put them on the shaft, there is no way to mess that up. Install the linkage onto the column, and slide the steering column up just enough to install the lower u-joint onto the rack (don't let anything turn at this point). Once the linkage is in place, reinstall the steering column mounts, then center and tighten the linkage.
There should be at least one threaded hole and there may be two threaded holes 90 degrees apart on all your DD joints for the steering linkage. If so, install a set screw into each one and secure with a jam nut. If not, there should be. I wouldn't weld them into place.
Andy
Old 03-12-2010, 06:22 PM
I have 3 inchs of 3/4 dd shaft in to the column then a 3/4 dd to 3/4 dd u joint. Then the 3/4 shaft to the rack u joint. Is this right, nothing pins or bolts the 3/4 shaft into the column??
Old 03-12-2010, 07:40 PM
aosborn's Avatar
Wiki Edits: 7
You can plug weld the shaft into the end of the column so it sticks out enough to install the upper u-joint. Be careful not to cook the bearing on the end of the column. Once all the joints are tight on the shaft, even if the weld broke on the column, it would rattle around but couldn't go anywhere.
Andy
How can you be sure when a cam is failing? 4speed57 Engine 9 09-22-2009 03:12 AM
Wich cam would you choose between these two? sbc 350 eric32 Engine 11 06-22-2009 05:57 PM
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
power steering Paco Suspension - Brakes - Steering 9 10-31-2006 06:02 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
