Steering universal joint - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2011, 06:09 AM
Hi,
I reticently install a manual R&P from a well known dealer. When I install the universal joint over the spline shaft on the R&P and tighten the bolt that goes thru the joint, I get a little up and down movement. When I call another large dealer of R&P's about their set up I was told that their joint does not have movement.
Is this movement something I should worry about? Would this movement eventually produce wear on the bolt??
Any help would be appreciated
Thanks in advance
Sam
Old 11-21-2011, 06:41 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Yes that is a concern..do some checking to see if you have the correct joint or if the one you have is worn somehow..
Sam
Old 11-21-2011, 03:13 PM
Sam
According to their tech this joint is recommend for the manual Dodge Omni rack. When I asked about the slight movement up and down he said just tighten it down so it doesn't come off. I asked to talk to someone esle and the answer was the same
Sam
Old 11-21-2011, 04:44 PM
Wiki Edits: 3
The bolt that is torqued runs in a slot on the shaft and if tha tis tight the joint will not come off..
Sam
Old 11-21-2011, 06:09 PM
Cape Cod Bob's Avatar
Be sure to use Loctite on the threads and the jamp nut !
Also check it periodiccally for tightness.
oddball universal joint gt68drvr Transmission - Rearend 4 12-07-2008 06:08 PM
universal joint-73 monte carlo ? bradykat Transmission - Rearend 1 05-21-2008 12:27 AM
Universal Joint ID onenew32 Transmission - Rearend 1 05-30-2005 07:32 AM
Universal joint replacement pcesak Transmission - Rearend 3 12-09-2002 04:14 PM
