Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Steering Vibration Part 2
Old 10-10-2011, 07:54 PM
user151's Avatar
user151 user151 is offline
Originally Posted by 1brewmaster1
Thanks for the responses...
The steering arms are parallel to the ground as are the control arms. ....
The alignment may very well solve your problem. But what I meant re the R&P arms was that they should be not only parallel to the lower A arms but the same length as them, and ideally their respective pivots would be vertically aligned.
The issue is somewhat like the issue with side steer where you want the drag link aligned with the wishbone.....
