Steering - want quicker ratio for 66 truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2006, 08:28 AM
My 66 pickup has already been converted to later model Power Steering (via a bolt on adapter plate) , but I want a quicker ratio. I THINK it now has a steering box from a early 70's pickup.
What other boxes will fit the truck and supply a quicker ratio. The current steering is way to light and offers no feel whatsoever. I think AGR and others offer new boxes, but I was hoping to go the junkyard or e-bay route.
Any help would be great!
Old 01-28-2006, 10:24 AM
A longer Pitman arm will make the steering QUICKER.....
Old 01-28-2006, 10:27 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Steering boxes
www.borgeson.com there are not that many patterns of those steering boxes..they may have something that will work for you..
OMT
Old 01-28-2006, 10:46 AM
powerrodsmike's Avatar
Wiki Edits: 161
If you put a longer pitman arm, put the matching idler arm too. If you want some more road feel try adjusting the pressure valve in the pump for less pressure.
BE different....ACT normal.
Old 01-28-2006, 10:57 AM
I was considering the longer pittman arm/idler arm route, but I think I'd rather swap the box out. I looked at borgeson, flaming river, and AGR.
I guess i am mainly trying to find out what fits off of passenger cars. Seems there are a lot of different boxes, but I don't know if other 800 series boxes will bolt on. Are they all the same overall dimensions and have the same output spline and output location? I can get whatever adapters are needed for the hoses and the input side.
If the g-body or f-body boxes work, i can get one of those.
Old 01-30-2006, 12:53 AM
I'm thinking the bolt holes are on the wrong side. Car boxes bolt to the inside of the frame, and truck boxes bolt to the outside.
A later-model truck box might be quicker, but it would likely be just as lacking in feel as yours.
Old 02-04-2006, 01:13 PM
Went the high dollar route anyway
Even though I was hoping to avoid spending so much, I ordered a new 12:1 box from AGR. They are pretty close to my house and I'll get the box next week.
Thanks to those who replied!!
Old 02-04-2006, 08:03 PM
cjr products in n.c. can Tailor your steering box to fit your needs they do it for the biggest part of the cup an bush teams they did mine for my nova ever driver has his own feel so thats what they do if your new box don't work out give them a call (336)766-2710 www.cjrproducts.com
Ford Truck Steering woes Kaylah Suspension - Brakes - Steering 4 08-15-2008 05:09 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
what's the best rearend ratio for my truck? chevyman355 Transmission - Rearend 1 01-29-2003 08:02 PM
Know anything about power steering on a 70 chevy truck? billp Hotrodders' Lounge 1 09-10-2002 04:02 PM
1956 Chev Truck Power Steering vaughan Suspension - Brakes - Steering 2 09-06-2002 12:11 PM
