Steering wheel adapter, 9 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2007, 01:28 AM
Hie everyone.
I have a stupid Swedish question. I have found a steering wheel at Budnik that I would like to fit on my Flaming river steering column. Budnik says that the steering wheel fits "For 1967-1994 GM vechicles only."
The question is. Is this 67-94 GM vehicle pattern the same as the 9 bolt pattern adaptor one can by at Flaming river:
http://www.flamingriver.com/index.cf...rod/prd156.htm
Best regards
Jimmy
Old 08-09-2007, 01:29 AM
The steering wheel in question is this one:
http://www.budnik.com/steeringwheels...2&pid=594&pg=1
Best regards
Jimmy
Old 08-09-2007, 01:35 PM
S10xGN's Avatar
Gotta love a turbo!
That particular GM column was splined. You used a (Grant) spline to 3-bolt aluminum adapter to fit the old style aftermarket wheels popular "back in the day". I guess everything changes, thus the "9-bolt" pattern, but I couldn't venture a guess as to what that Budnik wheel actually uses...
Russ
Old 08-10-2007, 09:21 PM
My three spoke sport wheel from a 1971 Buick has 6 bolt holes. I think the Budnik adapter will have whatever number of holes the Budnik steering wheel has -- where does it say 9 bolts?
One thing to note is that the Flaming River GM column is a slightly smaller diameter than a real GM column, so the adapter made by Flaming River is tapered to match their column. If you get the FR adapter I would expect it to have 6 holes in it and a taper at the column end.
The Budnik adapter might not have the taper to mate up with the FR column exactly, unless it is an adapter for a FR column.
I am using a standard GM hub with the GM sport wheel on a FR GM column. The combo works okay, but the mounting hub is slightly larger in diamter where it sets on the column -- doesn't look quite right, but functions okay.
John
Chevy steering wheel donor for 39 chevy? Chevy39 Interior 12 07-24-2009 09:00 AM
17 in steering wheel COVER ? 39chevy Interior 2 12-30-2006 06:54 PM
Removing '27 Steering Wheel from a '49 Column jasonbeam Suspension - Brakes - Steering 2 12-22-2006 08:25 PM
Need help fast.... Steering wheel just keeps spinning "70" Cougar Suspension - Brakes - Steering 3 03-23-2005 01:36 AM
To build own steering wheel or not neil madsen Interior 16 03-07-2003 01:30 AM
