Steering Wheel Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2005, 08:06 PM
Steering Wheel Help
I have a 70 chevy that I need to get the sterring wheel plate off. The only problem is that is thought I knew how but I was wrong. The three bolt holes that are in the steering mount are stripped and I want to replace it. But how to I get if off. I am no even sure that the steering column is origional any help please. Auto Zone have me a puller for a retainer plate but it will not thread onto the center column bolt.
ID:	6663   Click image for larger version
ID:	6664   Click image for larger version
Old 08-30-2005, 08:25 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
On most cars they are spring loaded for the column bearings. You can get someone to help you or buy a tool for about 5 bucks. You have to press down hard on the plate to overcome the spring pressure. Using a strong nail or old drill bit. Pry out the c clip. The plate will then come off.
Old 08-30-2005, 08:34 PM
steve t's Avatar
ex biker, now hotrodder
i may be wrong, but try a 3 prong gear puller
Old 08-30-2005, 09:47 PM
Looks like a common.....everyday Grant Steering Wheel adapter.....to me.
I suggest a 3 ear harmonic balancer puller.......and a little penetrating oil first...
DEUCE.....
Old 08-30-2005, 10:05 PM
It is the Grant steering wheel adapter. Should it just pull off is any thing else holding it on I dont want to break anything
thanks
Old 08-31-2005, 03:31 PM
thanks
It should just pull off (with some force) after you remove the nut on the steering column (which it looks like you already did). If you can't get bolts to hold in it you will need to use a 2 or 3-jaw puller to get it off.
Then put on a factory steering wheel because those grant ones are POS's
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 10:38 PM
Steering wheel decision help guba_unus Suspension - Brakes - Steering 2 02-12-2006 11:21 AM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 04:34 AM
Steering Wheel Adapters Question horvath Interior 17 06-26-2004 07:50 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
