Steering wheel installation? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2012, 08:30 AM
staleg's Avatar
Last journal entry: Hand brake
I know I have to use a puller to remove the GM steering wheel from the 1990 GM column. But how do I put it back on? Will it enter just by tighten the nut?
Old 03-13-2012, 08:58 AM
T-bucket23's Avatar
Wiki Edits: 26
Yes, slide it on and tighten the nut
Chet
Old 03-13-2012, 03:39 PM
What about the locking plate? This locks the steering wheel when key ie off. It needs to be installed befor steering wheel.
Old 03-13-2012, 04:02 PM
You need strong thumbs. Slide the locking plate down the shaft as far as it will go. Then slide the retaining ring down on top of the plate. Push the plate down past the detent then holding the plate with one hand take a small screwdriver and nudge the ring into the detent. Nothing to it.
Wheel Studs - Removal & Installation leejoy Transmission - Rearend 8 06-10-2008 11:32 AM
69 camaro steering wheel installation brads1966 Suspension - Brakes - Steering 1 12-26-2007 05:14 PM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 04:34 AM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 04:59 AM
Wheel Tub Installation 68NovaSS Body - Exterior 6 01-23-2003 07:54 AM
