steering wheel lock removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2008, 06:50 PM
I have a '70 Chevy Impala with the stock steering column (including column shifter) and I would like to know how to get rid of the steering wheel lock (when the key is not in the ignition).
Can anyone help me with that?
Thanks
Old 03-04-2008, 07:04 PM
pull the steering wheel. under that is a lock plate with u shaped knotches around the outside, the lock pin slides into one of those. you need a little tool that threads to the steering shaft and pushes the lock plate down a little ways, it's spring loaded. once you do that you will see a wire clip in a little groove in the steering shaft that holds the lock plate. pry the little wire clip out of the groove with a pick and the lock plate will come off.
Old 03-05-2008, 08:55 AM
That will work, but I think the lock plate is needed to act as a spacer in the whole steering column. You can cut the outer teeth off the lock plate and reinstall it, or just remove or cut off the pin that projects into the slots to lock it.
Old 03-05-2008, 09:33 AM
hey joe, removing the pin is a great idea, but he will have to disassemble the column further down to get the pin out. i have never left the lock plate out, i put them back together like i took them apart. i just assumed the spring under the lock plate would take care of any space issues. he could just stick a washer in there to replace the lock plate.
Chevy steering wheel donor for 39 chevy? Chevy39 Interior 12 07-24-2009 09:00 AM
What's needed to wire a horn at the steering wheel? jpd37 Electrical 9 06-22-2009 07:53 AM
37 Ford Pulling Steering Wheel 37FordCoupe Suspension - Brakes - Steering 12 01-28-2007 04:25 PM
Need help finding steering wheel instalation kit for 93 saturn goth_rod87 Interior 3 09-28-2005 09:02 PM
To build own steering wheel or not neil madsen Interior 16 03-07-2003 01:30 AM
