Steering Wheel Refinish - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2006, 07:00 AM
I did a search here and on the interior section. I am not sure if this is the right place for this, but with all the paint experts here I thought that I would check here first.
I have a stock steering wheel from a 66 bronco that I need to fix. It feels like a real hard rubber. I have fixed the crack with POR epoxy putty and I am not wanting to paint it.
Should I epoxy prime it or use some Vari-Prime self etch primer. Also what topcoat. I got some SEM for plastic or can I just paint it with some single stage urethane.
I first tried to rattle can paint it with fusion paint w/o primer and it did not like that at all.
Any help would be appreciated.
Old 05-17-2006, 03:34 PM
I would use a "vinyl" paint. You can get either rattle can or for a real paint gun. I would venture to say the real paint gun stuff would last longer on a steering wheel. Just make sure you use a very good viynl cleaner to prep with and you should consider using an adhesion promter as well.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
Steering wheel decision help guba_unus Suspension - Brakes - Steering 2 02-12-2006 10:21 AM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 03:34 AM
Steering Wheel Adapters Question horvath Interior 17 06-26-2004 06:50 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
