steering wheel swings b&f violently it you touch it - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2010, 12:52 PM
daoldbuick's Avatar
Started my rod for the first time today. It purred like a kitten. Man, what a rush that is. Then I thought I'd try the steering. As soon as I moved it a little it jerked out of my hands and started rocking back and forth violently. I quickly shut it off and started looking for the problem. Check fluid, empty. I had just topped it up but as I said this is the first time I had fired it up so I figured the fluid was pumped into the steering system so I toped it up again. Started it up again. Tried steering, same thing, steering wheel swings back and forth violently. shut it off and checked fluid again. This time it hadn't gone down. So now what do I do?
It's a new Ramjet 350 with the GM front accessory kit. It has the older GM canister pump. I had got a pump pressure reduction kit and installed it. It's a Mustang 2, IFS. The fluid I first put in was ATF fluid and then toped up the second time with PS fluid. All ideas where to look appreciated
Old 05-24-2010, 01:15 PM
Sounds like you have the presser line and return line reversed
OLDROD
Old 05-24-2010, 01:37 PM
daoldbuick's Avatar
OK I'll reverse them. If I remember correctly there was no instructions on witch went where. Thanks.
Old 05-24-2010, 01:53 PM
daoldbuick's Avatar
They would have to be in the hardest to access place on the car. So before I try and redo it, I have what I believe to be the pressure line ( its the biggest one with the heavy duty connector on the pump) going to the biggest hole ( the one that is closest to the splines shaft from the steering wheel). Is that backwards? I hope you can understand what I mean?
Old 05-24-2010, 02:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the lines are OK, be sure the belt tension is adaquate and that it is neither under or over filled.
Then bleed the system by jacking up the front wheels and go from lock to lock a dozen times (w/engine running) to purge the air from the system.
Don't hold the wheel against the internal stop, go slowly.
Old 05-24-2010, 02:19 PM
Small line is presser big hole/line is return line they are easy to get reversed as they are not a lot different. I an a experienced man as my brother did mine and it did the same thing AND that was after I told him more then once.
Oh yes the presser line was to short as I was useing braided line don't stretch worth a flip.
OLDROD
Old 05-24-2010, 03:04 PM
daoldbuick's Avatar
Thanks oldrod. I guess I know what I'm going to be doing this week.
Old 05-25-2010, 04:27 PM
When that happens to an RX-7 rack, it's because the 2 lines that go from the valve section to the piston section are reversed...it's applying assist to the wrong side of the piston.
Sticky Steering wheel on my 78 Camaro Z28 I just bought Juicer28 Hotrodding Basics 6 05-17-2010 07:27 PM
steering wheel splines?? raj4851 Suspension - Brakes - Steering 5 12-05-2009 07:53 AM
Steering wheel adapter, 9 bolt jimcar-9 Suspension - Brakes - Steering 3 08-10-2007 09:21 PM
steering wheel security, anyone try one of these? xxllmm4 Hotrodders' Lounge 6 02-08-2007 08:04 PM
Dyeing factory steering wheel? Hippie Interior 3 06-02-2005 03:33 PM
