Wired
It almost has to be a fuse,........ but, that opinion depends on wiring harness condition, quality of past work, recent modifications or disturbances, and/or any number of unknown things.
Try to figure out which wire is the "hot" (12V) wire at the alarm or at the stereo. Many times, but not always, the hot wire will be a red wire that may be a larger diameter than the other wires ....and maybe not. But a larger red wire is almost 100% sure a hot 12v wire.
Follow it back to where it either splices into another wire, or goes to the fuse box. See if you find a fuse holder in the wire as you trace it back. Obviously check the fuse in there if you find one.
If you trace the hot wire all the way back to the fuse box, then check the fuse at the location that the wire goes into.
I suggest you get a wiring diagram for your car, but if your harness is original, chances are good that it's a fire hazard waiting to happen, and a nightmare that will cause problem after problem. Find some help and get it re-wired.
Steve
