Stereo cutting out? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2011, 10:48 AM
GMCTRUCKS's Avatar
Stereo cutting out?
Stereo cutting out?
OK guys I have a older Alpine CDE-9874 in my truck and what is happening when I go up to high on the volume it turns off or it blinks off and on when it first started to happen I thought it was the connection because when I would push the head unit it the stereo would turn on. I thought it was the wiring harness so I bought another head unit off of Ebay with the wiring harness but just a while ago I put the unit I bought in my truck with the same harness from the old head unit and it's doing the same thing so what would you guys do next.
Change and use the wiring harness that came with this head unit I bought or is it the the faceplate bad? It's connected to the OEM factory wiring harness it just plugs in. Now the stereo always worked good it's just the cutting out that upsets me. I have another Alpine unit but I like this one because I use it with my I-Pod and the names come out on the screen and I can search for songs with this unit.
Thanks! RJ
Old 03-15-2011, 02:27 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by GMCTRUCKS
Stereo cutting out?
Thanks! RJ
Is this a new problem or has it always done this?
Old 03-15-2011, 02:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I think it's internal. JMO
Cole
Old 03-15-2011, 03:17 PM
DanTwoLakes's Avatar
Wiki Edits: 22
First of all, I would make sure the unit had a solid ground before throwing any more money at it. (My life would have been infinitely simpler if I had checked the ground every time before looking elsewhere for a problem.) This unit ( if it's an older unit) might be grounded by a metal to metal contact between the case and the dash, and loses contact when the knob is turned all the way up.
Secondly.........what type of unit is this, is it an older analog type? Because it's an older type, try turning the volume knob back and forth really fast. Sometimes if the knobs weren't used much they would get a little corrosion that would stop them from working in some places.
Old 03-15-2011, 03:33 PM
eloc431962's Avatar
Wiki Edits: 37
I agree Dan i have seen it all to many times a bad ground causing something like this.
Cole
Old 03-15-2011, 04:06 PM
GMCTRUCKS's Avatar
The problem hasn't always been there but now that im thinking the tabs holding the cage to the main unit there not even touching nothing because the main unit just slides out. That will do it right? I took it where I had it installed on day one because it started to happen months ago and I bet the guy didn't brace them correct and yesterday that my son installed the main unit that I just bought he didn't bend the tabs to secure the main unit to the cage so that makes me believe that it was never installed correct since day one and with the bumps in driving my truck I bet it was getting loose. Right? It's a digital stereo not a real old unit in fact it's a 2007 model unit.
Old 03-17-2011, 04:09 AM
EOD Guy's Avatar
There should be a blk ground wire in the wiring bundle.... and you can use the rear mounting stud (might need to install the stud) but in any case I don't believe the manufacture relied on the cage as a ground source....to many car consoles are plastic these days, hence no grd.
Old 03-17-2011, 07:11 AM
Wiki Edits: 22
I don't know how old a unit this is, but there were units (back in the day) that were grounded by contact with the case. And you're right, that would include the threaded metal stud on the back of the unit where a hanger strap was attached and then attached to the dash. If it's a newer unit from 2007, that's probably not the problem.
Old 03-17-2011, 07:15 AM
Wiki Edits: 31
What kind of truck? I know with some OBS Chevy's there is a school of thought that the bezel will hold the radio in and no mounting is nessasary..
As for the radio. check the grounds but aftermkt radios do fail
Old 03-24-2011, 09:38 AM
Coolball's Avatar
Last journal entry: First Entry 82' Camaro Z28 Project
You'll also want to check the 12v supply wires for loose connection as this will also cause what your describing.
Old 04-09-2011, 08:19 PM
How may speakers in parallel on each channel?
Maybe the amp is just protecting itself if the impedance is too low?
Old 09-07-2011, 12:29 PM
GMCTRUCKS's Avatar
I grounded stereo cage and stereo it self she working good now or it's been a while just a up-date.
http://youtu.be/drGMeIk8Q4I
Old 09-07-2011, 05:02 PM
EOD Guy's Avatar
good to hear you got it fixed
old looking new stereo/CD speedydeedy Hotrodders' Lounge 2 07-22-2008 09:44 AM
Cutting a hole for an in-dash stereo DanTwoLakes Hotrodding Basics 18 06-02-2008 06:45 PM
Stereo for my '34? staleg Electrical 1 12-27-2007 07:59 AM
Stereo help please. Novaman78 Electrical 4 11-02-2004 11:15 AM
stereo vs amp windmaster Electrical 5 08-12-2002 04:41 PM
