Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stewart water pump issue
Old 02-13-2013, 09:16 PM
skippy89's Avatar
skippy89 skippy89 is offline
All that is, is flashing from when it was molded. You can see the same material in the water passage of some new engines, as I did with my new small block. It's possible for it to come loose with operation, but unlikely to cause any harm in the form of plugging up the system. If you're really worried about it, just take a file or dremel to the flashing and get the loose material off. Then take a garden hose, or sink faucet and rinse it out. You can also leave it be, and wait for whatever actually wants to break loose, to come free. Then flush your entire cooling system, as a precaution, and simply preventative maintenance.
The Following 2 Users Say Thank You to skippy89 For This Useful Post:
61panhead (05-14-2013), panhead1961 (02-18-2013)
