Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stick welder - power supply
  #20 (permalink)
Old 10-20-2004, 07:03 AM
oldred oldred is offline
vorgarh-What size rod are you using? What power setting?
I looked at the description that you posted and the rod size limit is only 3/32" which is quite small but about the limit for a 110 volt machine, anything bigger will pop a breaker almost instantly and at the power setting required to burn even a rod that size the machine will have a very short duty cycle. That rod size limit also confirms what I already suspected that the 65 to 250 amp claim is wildly exaggerated with 30 to 90 amps being closer to reality with a short duty cycle on 110 volt but somewhat better on 220 volts. I assume that this machine is also AC only which will make it a bit harder to weld with but used within limitations it should work just fine. The proper type electrode(rod) is very important as some types are extremely difficult to use with AC so I would suggest a 1/16" E7014 or 1/16" E6013 for ease of use, the E7014 being the best in my opinion.
