Sticking steering wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2008, 01:58 AM
Hello. I just replaced a steering wheel on my '69 GTO and rewired the horn. After I repacked the lock plate and installed the steering wheel, my wheel won't center itself and seems to stick when I turn. Did I somehow pack the plate on too tight and this is causing this sticking? I'm wondering if I needed to regrease the spring area as it was a little gummy in there below the lock plate. Also, I did notice that the lock plate removal kit bent the lock plate slightly and it's a little askew. Could that lock plate being a little warped cause this too? I couldn't see how that could be considering the clearance I still had behind the plate.
Any help would be great. Thanks much!
Old 06-21-2008, 08:52 PM
Holder350's Avatar
Auto Parts Professional
yes the lock plate being bent could cause this....it spins with the wheel and could be hanging up on something.
I would disassemble again and try to straighten the lock plate....re-grease and then check again.
that is....considering that this is the ONLY thing that could be causing this
Steering wheel adapter, 9 bolt jimcar-9 Suspension - Brakes - Steering 3 08-10-2007 10:21 PM
steering wheel security, anyone try one of these? xxllmm4 Hotrodders' Lounge 6 02-08-2007 09:04 PM
Dyeing factory steering wheel? Hippie Interior 3 06-02-2005 04:33 PM
steering wheel adapter imgr8 Introduce Yourself 2 11-20-2004 04:20 AM
steering wheel hermangarza Interior 2 11-30-2003 11:02 PM
