Sticking a temp sensor in a drain plug hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2012, 12:28 PM
My TH400 pan has a drain plug. I want to stick a temp sensor in it. I don't see any reason why not, It should seal just fine.. right?
Old 09-09-2012, 11:55 PM
plugging a drain hole
Don't use pipe thread these are tapered and will give a false fit use straight threaded fitting and use tefflon thread tape in it
The Following User Says Thank You to jessedenny47 For This Useful Post:
0trbo4myCHEVUICK (09-10-2012)
What is this drain plug ? 64Joker Engine 1 08-15-2012 03:05 PM
muncie fluid change with no drain hole sapsz28 Transmission - Rearend 9 10-21-2011 09:53 AM
How I fixed my stripped oil pan drain hole Argess General Rodding Tech 13 07-19-2011 10:16 AM
Repairing a stripped oilpan drain plug hole Argess Engine 20 07-05-2011 09:21 PM
7/8-16 Oil Drain plug? Simplicity Engine 3 08-12-2009 07:55 AM
