sticky brakes
When I'm driving sometimes my brakes stick when I stop but not all the time and at the same time when I'm driving they seem to slowly stick and then I pull it back up while still driving with my foot. Changed the pads and rotorS and had a Mechanic look art it and work on it.I feel like they jacked me because same problems exist.
What car? The abs on my audi did something similar where it would feel like its sucking the pedal down when braking hard. Is this what it is?
sticking brakes ....
Of course, other things could be causing your problem, but this one certainly gave me my share of stomach discomforts. Good luck with your diagnostics. Cheers, Norman C |
Looks similar to below: http://inlinetube.com/clips%20brake%...uel/CLP505.jpg |
I'm most certainly gonna try the flex hoses, sounds more than likely that's the problem! Thanks for input!!!!
Brake flex lines, etc....
If you do replace the flex lines, please let us know your findings, either way. It may be of some value to someone else in the future.
Cheers, Norman C |
I will post my findings when I change those hoses..
| All times are GMT -6. The time now is 12:24 AM. |
