sticky speedometer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2005, 01:32 PM
montea's Avatar
tryn to learn
sticky speedometer?
in my 82 grand prix why does the spedo stick, i cant drive it yet because i dont have insuarnce or even primer but when i rolled down the driveway it went to 15kmh around 9 mph, wich could be correct but then when i stoped it just stayed there for a long time and finnaly droped back down again slowly.
i know it does leak tranny fluid out of the spedo cable hook up on the trans.
Old 03-02-2005, 09:12 AM
MI2600's Avatar
Member# 3287
It sounds like some rust may have formed in the speedometer head preventing the needle from dropping back to zero.
You have a 2-3 options. You can just drive it and hope it frees itself. You can remove it and gently lubricate it. Or, you can just replace it.
Old 03-03-2005, 05:40 PM
montea's Avatar
tryn to learn
ok thanks, i was reading some threads and its the bearing in the front that needs the oil?
Old 03-04-2005, 08:34 AM
MI2600's Avatar
Member# 3287
Probably. Speedometers are comparatively simple devices with a very cantankerous spring which you really don't want to mess with. The shaft rod the needle rotates on goes through a hole in the housing. That's where the problem probably lies.
Old 03-04-2005, 08:59 AM
poncho62's Avatar
Wiki Edits: 5
I wouldn't worry about it until you start driving it............might free itself up.
tv adjustment..i know!? pink63impala Transmission - Rearend 5 03-10-2005 10:34 AM
need help with carb hookup (trans cable) RodFather Engine 6 11-30-2004 06:35 PM
How can i extend the speedo cable. 7t2HQ Interior 6 11-19-2004 04:11 PM
Throttle Cable problem Jag Daddy Engine 2 05-30-2004 09:07 PM
a/t kickdown cable adjustment maddmaxx Engine 4 10-27-2003 08:04 AM
