Sticky Tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2005, 11:08 PM
juiced66malibu's Avatar
Sticky Tires
I am going to the Track soon and I am asking for recommendations on street and strip tires that are street legal and track friendly. I don't want true slicks but something in between. The widest tire I can put in my 66 Chevelle is 9 to 10 inches.
Old 08-16-2005, 11:35 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
sticky tires
As i dont know what gears you have and assuming you have a 15 inch rim I would suggest a 275/60r15 g/force t/a drag radial. 10 inches seems to small. My friend has a 67 chevelle and hes got 295/50r15 with no modifications. also the tires are pretty cheap at about 140 but will probably only last up to 10,000 miles if your lucky.Hope this helps.
Old 08-16-2005, 11:49 PM
Thanks for the reply. What is the tire maker? Also, yes I am using 15's. Have a Fab 9 rear end, 4.11 gears, 550hp.
Old 08-17-2005, 12:14 AM
1969NovaSS's Avatar
sticky tires
Those tires are made by bf goodrich, but if you got 4.11's and 550 hp i would defenitley get as wide a tire as possible. try looking at some sportsman II's they sell them at jegs and summit, just to see the sizes, and go to a good tire shop. they should be able to order them for you and have them in a couple days and they'll pay for shipping .
Old 08-23-2005, 02:11 PM
mrtimstik
Take a look at the Mickey Thompson Indy Profile II's. Not radial but the hook up nicely on my Chevy II. I'm running G-60's.
Old 08-23-2005, 02:49 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Try a set of M/T E.T. streets very good hook up.
or a set of Nitto drag radials also a very good hook up tire.
Steve
Old 08-23-2005, 09:17 PM
Rhansen's Avatar
Footbraker
Mickey Thompson makes a nice drag radial, best I've seen. The BFG's are also very good. Not too impressed with the Nittos on the strip but they will last longer than the others on the street.
Old 08-23-2005, 09:29 PM
New Member
i run 11s with mickey thompson radials when i drive to the track to race
Rear tires on a T-Bucket cucumber1949 Hotrodding Basics 7 08-05-2005 03:32 PM
Tires for 4" wheels dh79 General Rodding Tech 6 07-27-2005 07:37 PM
Big Truck Super Singles (tires) Flipper_1938 Suspension - Brakes - Steering 4 12-13-2003 07:07 PM
help slammed my chevy now tires rub vortec327 Suspension - Brakes - Steering 3 07-22-2003 11:18 AM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 09:54 AM
