stiff brakes wont stop - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2012, 02:07 AM
hello all i recently bought a 1974 f100. well the brakes are super stiff but i have to push the pedal to the floor to even try to stop luckily its a stick so ive been using my gears to help slow me down in this tank of a truck. the man i bought it from said he just recently replaced the rear drums on it. could there be air in the lines causing this problem ? thank you for the response
Old 10-19-2012, 08:50 AM
Dont drive on the street with bad brakes.
If the pedal hits the floor, you have air in the lines. Check the fluid level and bleed all four wheels and report back
Old 10-19-2012, 10:22 AM
Wiki Edits: 27
adjustment.
The rear shoes might need to be readjusted, Shoes too loose?
Old 10-19-2012, 11:13 AM
yea i planned on bleeding the brakes right away today i just wanted to double check what i thought was the right answer, ive never gone about adjusting shoes can you explain how ?
Old 10-19-2012, 05:11 PM
After further investigation I believe my master and booster are bad in the
Cab with the engine running I can hear air coming out when I apply pressure
To the brake pedal
Old 10-19-2012, 08:28 PM
stea's Avatar
Hard pedal and hearing air pressure I would assume the booster is shot.
Old 10-20-2012, 02:02 AM
yea im thinking so to and im seeing brake fluid on the booster so im going to replace the whole system hopefully when i finish tomorow ill report back and let everyone know how it goes
Old 10-22-2012, 05:30 PM
replaced the whole system master and booster bleed the entire system with new fluid now this tank stops like a newer car thank you everyone for your advice
got it to go and now it wont stop!!! jr19661966 Suspension - Brakes - Steering 1 12-28-2011 01:33 PM
wont stop leaking stroker444 Engine 1 05-20-2010 05:43 PM
sbc 383 wont stop smoking! please help! rlpater Engine 3 12-29-2009 04:24 AM
bubbles wont stop Wufei Suspension - Brakes - Steering 10 10-26-2004 07:09 PM
wont stop femadorob420 Suspension - Brakes - Steering 2 02-15-2003 03:38 PM
