Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Still on '69 Camaro Front air suspension
Old 11-06-2012, 06:40 AM
You can normally install a set of isolators to gain 1/2" to 1" at the wheel. You would have to remove the coil to get a upper and lower isolator on.
The down side to this is the farther you try to raise the suspension in its travel the more the camber curve is negatively effected. Its way to common for a guy to swap in a camaro clip and not position it correctly in its travel to match his desired ride height.
