Still getting no power after replacing the ignition switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2012, 01:13 PM
Hey guys I replaced my ignition switcg on my 85 s15. Still getting no power. Is there a fusible link somewhere?
Old 08-05-2012, 01:26 PM
yup a couple on the battery cable at the starter
Randy
Old 08-05-2012, 04:37 PM
What do they look like ??
Old 08-05-2012, 05:58 PM
S10 Racer's Avatar
http://www.warsprints.com
Should be behind the air cleaner on the firewall. There may be others too. Fusible links can look like wire so visually seeing them can be hard. The best thing to do is get a test light and start checking for power.
Old 08-05-2012, 06:10 PM
Found a burnt up wire tht goes to starter. Im guessing this powers the ignition. Does anybody know where the ignition wire from starter hooks into the ignition switch?
Old 08-06-2012, 07:16 PM
EOD Guy's Avatar
Not understanding your question, one end goes to the starter and the other goes to the firewall connector then to the netural safety switch then to the ing switch. Should be purple in color.
Old 08-08-2012, 04:18 AM
It may also be the rack and rod in the steering column. The physical ignition switch is mounted on the top of the column, and the rack and rod connects it to the electrical switch on the lower part of the column. If the rack breaks it usually happens gradually, so some ignition positions may work and others may not.
You can usually look at the outside of the column and see the rod that activates the electrical switch. Just turn the ignition switch back and forth and you should see the rod move along with the physical switch.
Bruce
69 camaro ignition switch loses power, pics....... Z27LS3 Electrical 11 08-23-2011 08:31 PM
No power when ignition switch engaged Joerod Electrical 5 12-07-2010 08:38 AM
Hot starter... How to install ignition power interrupt switch on the HEI +12v Robby5323 Engine 12 01-04-2010 09:15 AM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 06:04 PM
help replacing the high beam switch saenz5 Electrical 2 10-06-2004 06:36 PM
