Still have gas gauge problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 12:33 PM
I am having problems getting the gas gauge to work properly. This is a street rod and it was wired by someone else, so not sure if it was done properly. (Stewart Warner gauge 33 to 240 ohm. Sending unit the same ohm.)
I have disconnected the hot wire going to the gauge, connected a positive lead from the volt meter to that wire, connected the ground lead of the meter to a ground. I am getting 12 volts if the the key is on or off.
Isn't that supposed to be hot only when the key is turned on??
Old 03-31-2012, 03:08 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Connect to ignition ON.
Post the instructions for the sender. Can't find it on the net.
vicrod
Old 03-31-2012, 04:23 PM
EOD Guy's Avatar
Vic is right, you need to post the sending unit type/instructions, depending on your sending unit, you shouldn't have 12v from the wire going to the sending unit. The newer volume type sending unit does have a 12 wire going to the sender, but that's the only one I know of.
Old 03-31-2012, 04:24 PM
gto_ron's Avatar
With the multimeter set to the 0-2k ohms scale, what do you measure from the negative post of the gauge to ground. This is with nothing attached to the + post and the tank sending unit attached to the = post. It should be less than 240 ohms and more than 33 ohms.
regards
Ron
Old 04-01-2012, 08:09 PM
New gas gauge fixed the problem
Since the gas gauge was 26 years old, I replaced that with a new one and everything seams to be working properly now. I did re-calibrate the float less sending unit when I installed the new gauge.
Old 04-02-2012, 03:57 AM
EOD Guy's Avatar
good to hear you got it working.
Gas gauge problems Irelands child Electrical 8 10-27-2010 06:06 PM
Help!!! Fuel Gauge Problems 69Bowtie Electrical 6 08-10-2010 03:41 PM
fuel gauge problems Bracewell Engine 1 10-26-2009 05:19 PM
fuel gauge problems grapro Electrical 5 03-16-2009 01:13 PM
Fuel gauge problems 1969NovaSS Electrical 5 05-04-2006 11:42 PM
